Mariner 15HP 2 Stroke fuel problem.... I think
  • Thread starter Thread starter GSL
  • Start date Start date
GSL
8 Mar 2008
Me Cheltenham, boat Sant Carles de la Rapida
Hoping someone can help with what appears to be a flooding problem on my 15HP Mariner 2 stroke. It is a 2003 model.
Whenever I start the engine, even from cold, it is best to disconnect the fuel line straight after pumping the fuel bulb; otherwise it will not start as it appears to flood. Once running cleanly, fuel pipe re-connected and all is good.
The first problem occurred last week after running for about five minutes, as I slowed down to about ¼ throttle, the engine appeared to flood and stop running. I had arrived at my destination, and did not think much more about it. After about 15 minutes, the engine re-started, however it did appear to be flooded, and only started when I removed the fuel line and spent 3 – 4 minutes pulling the starter cord. Once started, fuel line re-connected, no problem.
No more problems that day.
Several days later, it started as normal when cold (fuel line off until running cleanly), we then covered 2 or 3 miles at varying throttle openings. When running back to the Marina at ¾ throttle and nicely on the plane, the engine lost power and stopped. My first thought was that the engine had seized, although there were no signs, sounds or smells of overheating. My immediate concern was to get the oars out and row back into the shelter of the Marina, as a strong off shore wind could have taken us away from land.
I left it, convinced that it was b______d, and only after about an hour, decided to try and start it. Usual cold start procedure, fuel pipe off, and it started with a lot of smoke, cleared and then ran perfectly, with no signs or sounds of problem. Fuel pipe re-connected, ran fine.
Any suggestions gratefully accepted.
Many thanks
Graham
well if it runs Ok wth the fuel line disconnected it is going to save you a bundle on fuel :D
Seriously it does sound as though it is probably flooding due to the needle valve not closing properly
It could be a defective or sticking float but very probably just a bit of muck in the needle valve.
I'd strip the carb down and have a look at these.
You do not say if its a US, European or Japanese made one or give the model number so not possible to give any details but you will find exploded diagrams, which may help, of the US/ European built models at http://www.crowleymarine.com/parts.cfm
Hopefully Cliveshep will see the question and add his views.
Is the valve that controls the fuel level in the float chamber sticking open? Might be worth stripping the carb and checking/cleaning it.
