Nicholas123
N/A
Using a high pressure gauge is a very crude way of performing a soundness test and not without pitfalls. More correctly it should be carried out without the bottle and regulator being connected by pressurising the system with air to 70mb, ie well above the normal operating pressure, and monitoring for pressure loss with a sensitive U tube manometer or the equivalent.
A far more satisfactory way for the individual to test an lpg system is by installing an Alde bubble leak detector http://www.alde.co.uk/itemdetails.php?itemId=53
60 seconds is then all the time it takes to check the system . It can easily be done every time the gas is turned on if desired.
Nonsense & unnecessary scaremongering.
