peter radclyffe
N/A
being dimensionally stable, in large sizes & long lasting, plywood has a lot of uses, there is a dutch company that builds all in ply, the interior of the boat first for access, then the hull, good idea
no boat that age is as sound as the day it was builtAs the owner of a 46 year old Marine Ply boat I can say that they will last as long as a GRP boat provided a few important conditions are met. First, of course is good quality ply, second is good surface protection, third is tackling any failure quickly and effectively.
old harry has identified all the major issues. In my case most are avoided by having a Cascover sheathed hull which is is sound as the day it was built. The unsheathed deck and coachroof are now mostly epoxy coated at the key exposed points such as deck edges and joins in panels. The non draining cockpit has always been covered with a waterproof cover and the boat is kept afloat all year round with a cover over it in the winter.
Preventative measures and regular maintenance deal with all the problems easily. Difficulty is that very few boats from the 50's and 60's have received such care, so many are past it. But if you can find one similar to mine (which I have owned for 30 years) you have a lifelong companion!
Molly, if you choke on Robbin's prices, try marinplyonline. Bought a batch of 9mm sight unseen. Pretty good. Actually worked out cheaper than the price listed.
A
Cascover is, I think, a nylon fabric set in recorcinol resin. The modern equivalent would be Dynel in epoxy. There has been discussion elsewhere on using polyester cloth, which is much the same, but loads cheaper. Some dress fabrics were mentioned.
A
Good tip - will check it out.
See, as I understand resorcinol IS waterproof but epoxy not really... there are some actual water absorbtion numbers for epoxy over wood/plywood here
http://www.woodenboat.com/forum/archive/index.php/t-7241.html
which ties in with what I have read elsewhere. The speculation that keeping the inside surface unpainted may allow the absorbed water to evaporate out is interesting.
Very interesting material. However, it is the way epoxy (or Cascover) is used that is important. Firstly, the ply itself is a composite - as a number of posts noted the glue itself is "waterproof" but the wood veneers have varying durability. Ply failure is almost always rot in an inner lamination - usually a less durable wood - and starts from either end grain absorption of water or damage of outer veneers. I can show you sections of ply cut from my coachroof that ring sound with perfect surface veneers, but the inner core is rotten because of an unsealed seam.
Sheathing either with Cascover or epoxy/glass cloth protects both the surface veneers but crucially the exposed end grains. It is very stable and if overpainted is effectively impermeable. Just coating with epoxy is less effective, but potentially better than conventional paints.
The ultimate success of such coatings depends on the integrity of the film, so is potentially less successful on flexible structures where the film may be put under stress or physically broken. That is what is so clever about the RM boats. They are ply cored epoxy bonded composites - a very different concept from a sheathed conventional wood structure.
Even the best ply does become brittle with age. Try breaking up a few ply boats and you will see what I mean.
Just keep of the rocks!
A
Based by Bristol
A
Molly,
A
