marine epoxy - safe for drinking water repair?
Burnham Bob
18 Jul 2009
Burnham on Crouch
If I have to make a repair with marine epoxy will it be safe to drink water that contacts the repair - both hot and cold?
Can't see why not but forumites might know better.
I have made and repaired more than I can remember, never a problem.
It's common practice to line poly resin tanks with an epoxy be they for drinking or sewage.
Good luck and fair winds. ;)
Many epoxies are prone to generating by products.
Amine blush being one name for this kind of process.
I don't want any of that in my tea, thanks.
There are lots of different epoxies.
Find a food grade one and stick to the instructions (pun intended).
Well, I'm still alive. And (thanks to this board) I've even heard of a blue-water sailor who fixed a tooth with epoxy.
BTW We've also been painting the inside of our water-tanks with epoxy paint for many years, most recently using Altex AltraShield 2000 polyamide epoxy with Altex X-100 thinner, which is recommended for this purpose. If you do have doubts about your marine epoxy fix, you could always cover it with something like this.
Anything recommended by a manufacturer for water tanks has to have a potable water tank certificate. This is expensive to get and expensive to maintain.
All the major marine paint suppliers used to have potable water tank coatings in their yacht ranges but have discontinued due to cost and small market size. They still have them available in commercial pack sizes for ships tanks.
Usually they will be high solids pure epoxies and if you use one of those then you will almost certainly be OK.
In answer to one of the comments above high solids epoxies will probably suffer amine blush under certain application conditions. This is a once off event when first applied and is simply removed by washing with fresh water. It is colourless, odourless and tasteless so even if you immediately filled your tanks and managed to drink some you wouldn't know about it
