CapPugwash
Hello boys and girls (and everything in between)
I am about to overhaul my wiring and have created the diagram below. It shows how I am intending to connect everything. As part of the process I am adding a Victron BMV-712 battery monitor and shunt. There is a Victron Cyrix-CT Battery combiner that connects the positive to the domestic battery bank when the alternator is charging. This disconnects when the voltage drops to 12.8 volts on either side. I am considering adding a relay that is triggered by the ignition switch to resolve this.
However, I am unsure how to connect the Stater Battery negative so that it doesn't bypass the shunt. I have thought of running it a longer a distance so that it becomes the longest route. I feel that it will still bypass the shunt though. Maybe I could add ignition controlled relay to the negative too?
I'm also not sure how the engine is grounded, I'll work that out at the weekend. I am guessing it is via the starter motor.
