Boats like that clean up very easily
off topic slightly - but what did you use to get the exterior cleaned up in the end?tell my back that?
Pressure washer, hand scrub, oxyalic acid, 4 passes with reducing cut compounds, polish then a wax
View attachment 126188View attachment 126192
Nobody should feel obliged to take their boat out on every visit. If you like staying on board in the marina then there's nothing wrong with that.
But boats (engines, etc) do suffer from lack of use so I think the occasional run is really beneficial.
And wives should be strongly discouraged from filling the boat with ornaments, tables lamps, or anything else that makes prepping the boat for going to see a chore.
Thank you BP……that was the easy bit! ???Now that is a real credit to all your hard work. She looks lovely. Worth the back ache.... I think but then it was not my Back
Polishing is certainly your forteThank you BP……that was the easy bit! ???
Sounds like paradise for boat buying! ??Hull Marina has boats in there that haven't shifted in over 10 years
Better than the Caribean with the Brown muddy water of the Humber estuary what more could you want.Sounds like paradise for boat buying! ??
might get you to drop a card aboard ??Better than the Caribean with the Brown muddy water of the Humber estuary what more could you want.
There is a large 50 ft + Azimut in there hasnt moved for years probably never been lifted and is not a live a board
A friend re-named it 'The Chocolate River'......the Brown muddy water of the Humber estuary............
1997 Azimut 58 Motor Yacht for sale - YachtWorldBetter than the Caribean with the Brown muddy water of the Humber estuary what more could you want.
Now thats a coincidence - There's only a few photos of the actual boat the rest look like brochure shots
I see the broker is not local to the boat. That could explain the use of brochure shots.Now thats a coincidence - There's only a few photos of the actual boat the rest look like brochure shots
