Halo
I am also thinking of fitting composite skin fittings and seacocks this winter. One thing really attracting me to them is that I can ditch the ugly great zinc anode from under the valve cluster !
Have a look at Tru Design valves and fittings. They don't appear to be much more bulky than the DZR alternatives and seem extremely robust. http://www.leesan.com stock them in various sizes. Have a look at their web site, http://www.trudesignplastics.com/products/45-ball_valves.
Sorry to contradict some pf the posts above
DZR does breakdown on GRP
The Hanse Owners forum has a long thread on the matter
In addition the valves & fittings breakdown
This seems to be particularly prevalent when there is items like electric toilets & the valves etc disintegrate on the foul water outlets
I posted a picture of a DZR fitting above the valve that just fell apart in my hand after 8 years on the Hanse owners forum
If you are interested it is in "chit chat" under seacocks
Do you actually need the anode at the moment?
The picture - of a skin fitting I removed last winter says it all as you an see the de-zinced section - after 5 years in water
The more I look into this the more confused I get................
If I look at DZR valves, what material does the through hulls, bends and hose tails need to be.
I thought electrolysis and dezincification were separate things? Though I admit I'm no expert.
What were those skin fittings made of?
Not quite correct as you will see from the post above. Your skin fitting looks like plain cheap brass which is prone to dezincification in salt water. That would not happen with DZR - as its name implies it is dezincification resistant. It could still, however happen if the fitting was connected electrically to a dissimilar metal, in which case an anode may be required linked to both.Pete
I think the fittings were/are DZR brass (but not sure to be honest) which is another reason why I am changing the rest.
I believe that electrolysis is the process which drives de-zincification. The zinc part of the alloy dissolves away leaving the copper part. The copper is darker than the zinc (which is grey) so that is why there is a dark ring on the inside of the fitting in my picture. The remaining copper is much weaker and looks different.
Bronze is better than brass because it does not have much (if any) zinc in it.
Whenever there are different metals together in salt water a similar process attacks one of the metals.
Zinc anodes are used as a sacrifice to be sure that the important metal parts are proteced from electrolysis but need to be connected eletcrically with the zinc anode in the sea water
That is my laymans understanding of what happens and I hope it helps
Martin
This is not the case with skin fittings through GRP. They are not connected to anything
However, even if you do that, and read Vyv Coxs additional articles on the subject you will still be confused as to what builders actually fit. This is because they either won't say or more likely don't always know.I suggest anyone concerned about this subject read the YM article as this does seem to be more informative with fact rather than fiction or opinion
Troubador
Hanse say they fit DZR
My fitting just collapsed in my hand and any reference. Would have been unreadable
The new DZR fittings had no marking & the chandlery had brass, DZR & bronze all next to each other on the same shelf. I only have the managers word that I have DZR as I have no idea if the fittings could have got mixed up
Another contributor to this thread says skin fittings are Bronze. Unfortunately that is misleading. It has been recorded in the Hanse forum that other manufacturers do not necessarily fit bronze. The EU rules -according to extensive reporting by Yachting Monthly is that the fittings used have to last 5 years.
The ASAP site I referred to above very clearly shows the material for each fitting so you can buy with confidence.
