Playtime
Any suggestions?
Have you had the GPS working with any programme on that machine? If not, then maybe you need to sort out the driver - see the manufacturer's instructions for how to get the GPS driver loaded.
If you have had it working, when you run OpenCPN, is there any other programme running at the same time that uses the GPS? If so, close the other programme and restart OpenCPN. A COM port can only be connected to one programme at a time (unless a virtual port is created which you are probably not into - yet!).
If it still doesn't work, look in Device Manager and check that COM8 actually has the GPS attached.
If all that fails, I give in (again!).
