flotsam123
Hi - does anyone know how many man hours can I expect to be charged to remove an old Volvo engine and replace it with a reconditioned Volvo? Has anyone had a similar experience?
If it's like for like then about one day. If substantially different then up to a week.
Good point Paul. I was thinking of an outdrive jobby with easy access straight into the cockpit!
What do you think is likely to happen to the sterndrive leg once it is disconnected from the main engine assembly and just left dangling out of the back of the boat once the engine has been removed.
Simple answer.
DPE /DPH type drives have to be removed to enable access to the 6 bolts that sandwich the bobtail housing through the shield, you cant remove the engine without, unless you split the engine at the bellhousing, which is not the correct way in volvos eyes.
Sx type drives, you undo the rams and 6 nuts, pull off the drive as the shaft goes right through the shield into the drive coupling on the flywheel, you can then remove the 2 rear bolts onto the shield, similar to a mercruiser, and the 2 front feet.
I know this is an old thread but I noticed that in order to change the engine a couple of people have stated the leg needs to come off.
If there is enough room to slide the engine forward I wondered if this was still the case and why?
