MAN Engines Built in 1970
Shaka 1
12 Nov 2012
Indonesia
Has anyone got any ideas on how to get information on these engines?
I wish i could give you more information but not in a knowledgeable position to do this...
Would love to get some manuals on them if someone knows how o do this?
Would also love to know how best to work out the fuel usage as well.
Thanks,
Shaka 1
Thanks,
Shaka 1
Plenty of information but what engine range, do we assume old 25XX V motors or six pot??
Without being specific all pretty pointless.................
Yes your are right...
Thats my problem though...i dont know enough to give you further info???
Today i got pictures of the engines but i dont know how to post them up here so you can see them?
I did get some numbers stamped on the block though...not sure if these would help?
I really do appreciate your reply no matter how small the information!
Getting the manuals would be my ultimate goal!!!
The numbers i got are;
The most relevant numbers that I can find are; 51.01101 – 3284 60
With what looks like a date stamp of; 26-11-90
Does that help?
I'm sure the pictures would help too...
the vessel is the one in my avatar...
Thank you.
set up a photobucket account
http://www.satisfaction.com/photobucket-login/
Does that help?
Thank you.
How large are the engines??
MAN high speed engines from around the 1970's are derived from a JV with Mercedes Benz, inline 5, 6 and V motor configurations from V6 to V18.
MAN medium speed engines are B&W designs now marketed as MAN B&W, smallest of these is about five tonnes. Looking at your Avatar wrong class of vessel for a 750 rpm engine.
Surely you must have a clue to the number of cylinders, configuration, power output and rated speed.
Let me take a punt, MAN 2840 V10 800 to 1,000 hp.
Bilgediver,
I think OP may have found answers elsewhere.
Well done to identify as 25XX Series which was my first suggestion. think you did switcheroo bore with stroke, in-line 5 and 6 were 125mm bore and 155mm stroke, the V versions were 145mm stroke. 28XX engines saw bore increase to 128mm.
Base motor is same as old MTU 183 Series.
