stranded
Want to try to take some friction out of the Genoa furling system and also get a more comfortable fit on the drum (Furlex 300s) when we revert to our 150% genny in the spring.
At the moment I can haul in by hand in most conditions but I really have to put my whole (considerable) body weight into it to get it moving, after which it is just a good workout. The boss though has to use the winch.
And the current 10mm line is a really tight fit in the drum such that any imperfection in hoisting and it rubs the insideso getting the first few turns of sail out can then be another tug of war.
I have done very little by way of splicing beyond lazy jacks, so just want to check the plan before I splash the cash…
1. is a 6mm dyneema to 12mm doublebraid tapered splice OK from the point of view of the integrity of the connection and and easy passage through the furling line blocks, which are under deck and so not accessible without removing headlining panels?
2. Would 8mm dyneema be significantly better from this point of view, and would it still yield a significantly smaller diameter on the drum.
3. I plan on dyneema to just forward of the deck organiser, which is just in front of the winch, which I think is about equal to J, then ‘sufficient’ double braid. If there is a reason I should have less dyneema, which, depending on the answer to 2. might mean I have to opt for 6mm to get the doublebraid to fit on the drum, what are the relative advantages/disadvantages of, say, 8mm dyneema = J against 6mm dyneema = 1/2J?
Does this make sense? Would it work? And what should I be doing.
If it does work then I might try a similar with the single line reefing lines…
Thank you in advance for any advice.
