Lomax
Making oak laminated plywood floor panels
I'm about to start making a new floor for my boat, and want to try something a little bit different: I plan to glue 2mm thick oak "boards" to 15mm WBP plywood sheets, from which the panels will be cut. The plywood will be painted on the back and sides (for moisture proofing), and the oak will be treated with oil or wax after the panels have been installed. Because it will be difficult to apply pressure across full size plywood sheets, and because some flexibility of the glue is desirable, I'm thinking of using an epoxy glue, but thought I'd check here first if anyone have any thoughts. Should I be using a different type of glue?
