Making a Dan Buoy.: Waterproof container, builders foam
davidpbo
14 Aug 2005
Boatless in Cheshire. Formerly 23ft Jeanneau Tonic
myweb.tiscali.co.uk
I want to make a Dan Buoy to aid picking up our home mooring.
I have the weighted upright scavenged from a skip to make a Dan Buoy, I have a container (Not watertight) formerly used for wet wipes, drilled top and bottom. I am considering filling it with foam. Am I right in thinking the usual builders foam is NOT closed cell and will absorb water?
Alternatively:
Can anyone think of a top hat style fitting that will fit over the pole (12mm ext dia.) and give a decent flange to glue to the float where the pole passes through.
or point me in the direction of a small buoy with hole through it to take the pole.
Our mooring is in fresh water.
T.I.A. David
I made a dan buoy for my previous boat. The float was a 1 1/2 litre plastic beer bottle rammed full of polystyrene beads. I fibre-glassed over the plastic bottle and painted it. It lasted years and may still be in use.
I was going to check if polystyrene was closed cell. We get a lot of packing "Worms". I think it is and you seem to confirm it.
