Twister_Ken
...nor can I visualise falling out of the boat in lighter conditions.
I've done that. Fireball. Toestrap fitting pulled out. Crew was very surprised as I surfed along behind the boat, holding onto the mainsheet.
I am sceptical of things like pop bottles, it might help for beginners practising in flat water, but once you get out in waves, it can take a lot to stop a boat inverting if it rolls in at speed.
I had neglected to put a stopper knot on the main sheet and it ran out. Plus, I fell on the rudder head and bust it.. So ran to Flushing with one foot on the rudder blade and the jib for drive.
I carry 40kg ballast if alone...
Seriously !?
Anything you use for melting / casting needs to be bone dry or you risk a steam explosion spraying molten lead at you - or at the very best, porosity in the casting.
Hmm...
That's seamanship! Great story. Did you wear a lifejacket back then?
What form does the 40kg take? I'm very interested.![]()
I think you'll find ballast is placed centrally specifically to avoid inertia, pitching, but this is a dinghy not a trad' dayboat or yacht.
Hmm, I wondered about that. I was hoping to hear that DownWest used a bit of flamboyant DIY ingeniousness - water ballast tanks on a sliding seat, something like that.
Since the ballast is eitherside of the board case it only affects the roll, not pitch (much). But I only put it in if the wind is a bit fresh.
Quite like the idea of water on sliding seats, but bound to catch you out by being on the wrong side in a moment of interest.
About the same time I was finding my way solo, father built a foiling tri. Symetrical wing sail with a 'soft' sail off the trailing edge and a fully batterned jib. The pitch control was by two rudders in an inverted V. They worked together to steer and acted as a elevator for the pitch. A system used on some aircraft (well, he was an aerodynamacist) like the Beech V35 Bonanza. The main foil was under the mast and when it started to get up, was very unstable, so frequent duckings resulted. Usually by nosing under and coming to a dead stop with the tail in the air. Quite rightly, I was not allowed on it, partly because the only place to sit was the curved box that joined the hulls together, which had a flat top with no coamings. Bit like an Int canoe. It grew a large angled bow plate, which stopped the porpoising, but was never easy to sail, just very fast.
About the same time I was finding my way solo, father built a foiling tri...never easy to sail, just very fast.
Dan,
while winter dreaming is great and we all do it, it really comes down to - DO A CAPSIZE TEST !
Agree with Andy. We did a few capsizes in the Grad this summer, at first SWMBO was very nervous but she actually really enjoyed it in the end. The worst that happens is that you get a bit wet. Incredibly reassuring to realise that it's not the end of the world after all.
do you actually know how easily you can right the boat as it is?
Dan,
I know this is all just winter fireside chat but you're worrying about nothing.
I think a couple of those were on ebay a while back? Some discussion on the y&y forum.....
DownWest,
I'd love to see a pic of your Fathers' foiler, was it anything like this ?
