Gounge
New Member
Hi Guys,
I own an Orkney coastliner 14ft fishing boat on a snipe trailer. Ive only had it since May last year and want to make sure I keep it well maintained so a few questions for you seasoned pros please:
1. The trailer goes in and out of the sea on launching, it is showing minor signs of rust. Is there something I can paint the trailer with before the season to help waterproof it? I am going to use white grease for the wheel bearings but any other suggestions greatly appreciated.
2. There is a small storage compartment at the front made from ply wood and also the sea at the front has some ply on it which is now beginning to warp and peel. Is there something plastic/PVC that I can replace these with to make them more weather resistant in the long run?
3. The fuel has been sat in the tank since last used in October and the engine was last run through in early December- should I replace this fuel or will it be ok to run the engine through with?
Thanks in advance for your help guys!
Dave
Dave
