The forward double block is probably the the one causing the most trouble, because if the twist induced by the line going forward.
A better set up would be with triple block at the aft point on the boom and a single block forward. You would Al's do better with the aft boom block directly over the one on the track.
I'm definitely swopping to dyneema, anything for a friction free life!I found my 14mm sheet with a rather "fluffy" casing had lots of friction. I changed to 10mm dyneema with a slippery outer casing which totally transformed things.
As most of the time my sheets are used in a winch this worked well for me.
I was going to go for them, but wondered if they might be too "tech" for cruising? Happy to be proved wrong though if you have experience.It does look rather complex. And I suspect those blocks are all plain axle designs. Had you thought of using new ball bearing blocks?
Now that sounds like simplicity itself! Thanks Roger.I agree a triple block on the boom with the track triple block set at 90 degrees to the upper block on the line going forward coming from the center sheave of the upper block .
If you're concerned about friction in the system, ball bearing blocks should certainly help reduce it. I've got them on my boat.
Yes I have looked at you post again just to point out that ball bearings of any kink are not good for a static loaded bearing as the balls tend to dig into the ball races.
PTFE lined or Oilite bushes are much better as it gibes low friction of PTFE whit the load carrying capacity of a plain bush.
The are various different types of plastic that could be used I tend to use vesconite in most of my designs
Perhaps you should offer your advice to the technical people at Harken, Lewmar, Ronstan and other manufacturers who offer low-friction ball-bearing blocks for high load applications. I'm sure they'd value your thoughts.
What they are doing is supplying goods to the cheque book sailors who don't know better.
The block at the mast foot doesn't look too happy, rope rubbing on side cheek. Does it have a swivel base?
Yes, good spot. That might be best with a dyneema rope lashing- allow flex to align, but not to over rotate when looseThe block at the mast foot doesn't look too happy, rope rubbing on side cheek. Does it have a swivel base?
