Main halyard splice damage?
Captain Crisp
1 Mar 2015
Hi my main halyard has a worn out section on the outer braid. I'm planning to reverse it and splice the thimble on the other end.
I think the damage is where the splicing needle exited the braid. Is that a common weak spot? Can it be avoided?
Crisp
Laysula
1 Jun 2008
Brixham
You'll never splice an old rope. Just cut it and tie a halyard knot.No need to reverse ir as you will have moved any wear points along a bit.
AntarcticPilot
4 May 2007
Cambridge, UK
www.cooperandyau.co.uk
You'll find it very difficult to splice old braid on braid. It loses some elasticity, and "milking" the slice when finishing it becomes VERY difficult, and may be impossible.
I don't splice my main halyard; I use the halyard hitch. The problem with a splice is that it introduces quite a long stretch of increased diameter and reduced flexibility between the thimble and the end of the splice. Almost certainly, the wear you are seeing is down to that. Using the halyard hitch avoids the increased diameter and reduced flexibility allowing the peak of the sail to be hoisted higher without extra wear.
Tranona
10 Nov 2007
Support the use of the hitch. However can be difficult with hard old rope, so best to wash it first to get the dirt and salt out. Downside is that you can expose other worn bits and get ruptures elsewhere on the rope reminding you that it ha a finite life!
dunedin
3 Feb 2004
We also use the (Jeannea) halyard hitch. We winch it tight between two winches to ensure is fully taken up before using to hoist a sail, which would be worth doing on an older rope to ensure it is secure.
