Seagreen
Is this possible? The only reasonable position for a magnetic steering compass is about 2 feet from the engine - not ideal by any means. So I thought that covering most of the engine box in a wire mesh (securely holding on the insulation anyway) would help to create a Faraday cage effect and neutralise the Deviation in some way. Is this likely? I'm going to do a Dev. table for the compasses anyway, but I'd like to try and reduce the errors. I think I get a 45 deg. error at the moment.
The only other alternative is an edge reader like a Sestrel Moore type, but again, that would be very vulnerable to being torn off or stepped on.
