Csail
N/A
I borrowed one of the cops maglights and its way brighter than the same as i use....its a 2 dd cell one so what bulb do i get?
Maybe it had the newer LED in it. Much better performance but not as good as Lenser.I borrowed one of the cops maglights and its way brighter than the same as i use....its a 2 dd cell one so what bulb do i get?
Torches have improved dramatically since the Maglight.
There are LED replacement dropins that contain a new LED and driver. This is how the Maglight you used was so bright. The good dropins are expensive and unless you have a sentimental attachment to an old Maglight you are better getting a complete new torch.
If you can give details of your preferred batteries, size and use of torch I will recommend something suitable.
That's only true of the cheap ones. There's no reason why an LED torch shouldn't be better than any other type.but LED dont have much range do they ???
also give a horrid dazzling light
You are thinking of the 5mm Leds. The new torches use a different kind of LED. Typical results will have 3X the range and 10x the output of a 4D Maglite. The beam is much better with no rings or artifacts which greatly improves visibility.but LED dont have much range do they ???
Forget what you think you know about LED torches a good modern model is completely different to what you buy in the hardware store.
Its a pity more boat owners don’t have one they are a great, perhaps essential, piece of safety gear if nothing else.
For the 2D I would replace if with a Fenix TK50i have a 4D & a 2 cell AAA
what would you recommend
http://www.flashaholics.co.uk/fenix/fenix-tk50-flashlight.html
For the 2XAAA a single AA would be a better option unless AAA is essential it is brighter than the and it gives you a very small torch with in conjunction with the much larger TK50 covers most of the options.
Quark single AA model
http://www.flashaholics.co.uk/4sevens/quark-aa-tactical-s2.html
The other possibility for a single AA is the Zebralight. This can also be used as a headtorch its very small and bright, but it has a very wide beam. The beam distribution is great for things like working on the engine, but it it will not pick up distant objects as well as the Quark (The larger TK50 is ideal for this so both torches would still cover all circumstances)
http://www.flashaholics.co.uk/zebralight/zebralight-h51.html
There is one other advantage of the 4D and 3D Maglites we seem to be missing. That is, if you happened to come across an intruder whilst the torch was, let's say in its most comfortable position, i.e. laying over your shoulder with your hand holding the lens end and you happened to, by accident, have brought it down sharply in a forward arc, you could not be accused of being anything other than surprised and acting as such... despite the fact that you were carrying a metal cosh of c.2 kilos!
Forgive me but a AAA torch, whatever its light output, is not going to cut it when faced with a piece of humanity intent on robbing you of your hard earned belongings.
Many of the new torches have "tactical "features.There is one other advantage of the 4D and 3D Maglites we seem to be missing. That is, if you happened to come across an intruder whilst the torch was, let's say in its most comfortable position, i.e. laying over your shoulder with your hand holding the lens end and you happened to, by accident, have brought it down sharply in a forward arc, you could not be accused of being anything other than surprised and acting as such... despite the fact that you were carrying a metal cosh of c.2 kilos!
I saw one of the new 2D cell Maglites in B&Q and was so impressed I bought it and replaced the floodlight on the boat with it. I then read about the 'Nite Ize' 1 Watt LED conversion for existing 'normal' Maglites so I bought one and fitted it to our old incandescent 2D cell Maglite. Big mistake. It is nowhere near as good as the new genuine LED torches and I would buy a new one any day.
Was it one of these:
