BikerBry
New Member
It will make a difference whether you have lead or concrete. Whether it makes enough of a difference to have a practical effect in the case of a Kelpie I don't know.
As the concrete is much lighter, for the same volume, than lead, if you have the same weight it will be significantly larger in volume. In the confines of a boat keel that means that the centre of gravity is higher up. As you have the same weight the boat will float to the same level, but with concrete you will have a lower righting moment - i.e. the boat will heel over more readily, and come upright again more slowly. I don't know in the case of the Kelpie whether the difference will be enough to notice or have any practical effect.
I wonder what the original design called for. An alternative to lead and concrete, very popular in the era of the Kelpie, was steel punchings encased in polyester resin. This will be significantly smaller than concrete for the same weight (and hence lower centre of gravity), but not as small (or low) as lead. You can find the relative weights/volumes on the internet.
