jfm
Hurricane I'm with Jimmy on the maths. And, referring back to the points above, I'm confident mine don't draw 5A per light and I new see that's due to fact I dont run them on high power white. I think i said my 6 lights draw 10 or 12A and EME has said it's gotta be 15A, fair enough, but anyway it's that order of mag. That's peanuts on a boat your size... and that all assumes you've got the x120's which are monster powerful, and that you're running them in bright white, which you probably wouldn't be. An alternative would be the surface mount lights, which when you run them in cyan (which I do) at 24v would draw about 1.7A per unit - or 5A total.
Cheers
Jimmy
I share your preference of not running gneset in evenings at anchor, once the cooking is finished (MYAG - our bit of the planet is cooler than your manor so airco isn't needed). So all lighting, fridges, icemakers, music and uw lights run off batteries and with care I can get the total draw down to 50 amps or so depending on the cutting in-and-out of the fridges/freezer/icemaker. I find that's fine for say 5 hours, then stuff shuts down at night leaving only the fridges and I start a genset in the morning to recharge batteries. Surely you'd follow a similar profile?
The right lighting install on your boat, to suit its size, is 4 x thru hull 120watts, ie the current version of the lights in my pics above, which were a bit OTT on a 58er but just right for your 70er imho
