sabresailor
I might spend a night in Lulworth Cove tomorrow (24 ft bilge keeler). Does anyone know if there is a buoy I could borrow? Or is it only authoring?
Mike
Mike
Mike
I'd second Vic's suggestion and recommend you give Lulworth a miss and go to Worbarrow as far more comfortable and safer. As to mooring buoys, they usually belong to someone else and it's gross bad manners to use them, without the owners permission (apart from the fact that they might be meant for an 11' dinghy.)
It can be reasonably argued that it's gross bad manners to occupy a small anchorage with a buoy that prevents others anchoring in that position. Fair enough if theres plenty of space otherwise. Any mooring has to be laid to take its usual boat in a storm, so unless the OP hangs on it through that he is unlikely to overstress a mooring in serviceable condition, which if it isn't is even worse bad manners for wasting the anchoring opportunity altogether to nobodys benefit.
If the owner arrives it is to be expected that the visitor leaves,so he should not leave the boat, but I don't see it as bad manners to occupy a mooring. It might be dodgy practice, not knowing what condition it's in, but not for the reasons above.
We might own the mooring, but not the space, we only get a licence to have a mooring laid.
Shall we agree to disagree on the subject? No doubt you'd be equally relaxed about someone borrowing your dinghy to row out to a friend anchored off?
As far as I am concerned I will happily pick up a mooring I deem suitable in fair weather, if some one asks me to move I will be onboard to move off...
There has been countless threads on this and variations there off, always guaranteed to get the forums alight.. The similarities between borrowing a dinghy are hugely different, the fact is we sail in an increasingly crowded waterway. Means continuing small acts of friendliness/ understanding will make boating whole lot less pleasant...
That assumes everyone has your view and remains onboard, I've returned to our mooring after a after tea sail to find a yacht on it and the owner gone ashore.
What we need is the universal sailor, everyone singing to the same song sheet.
Brian
