Lubricating furler drum
Need to know the model.
When I had a Furlex I used the Selden blue grease and injected grease with a plastic syringe from Boots. It needed the clamshell off first.
My sailmaker recently said the silicone spray is as good as anything else.
Also see this recent thread:
http://www.ybw.com/forums/showthread.php?t=312952&highlight=furlex
Don't forget the top swivel too.
If you have a Furlex you can download the instructions from the Selden site. There are 4 points lubricate. 3 are easy and the fourth a bit more tricky, but needs doing less often. I have just done mine with Lewmar grease, administered with a syringe so goes straight into the holes with no mess.
My reefing furler is a Colnbrook Seareef and lubrication is made to a hole in the lower section of the foil, about 3-4 inches above the spool, a 3 in 1 oil is recommended for this one; I only discovered mine by accident reading in some of the manuals I had, and what a difference it makes!!
Grease or oil I guess is the proper lubricant where needed - not WD40 or similar.
The upper swivels on some rigs are 'sealed' bearings and cannot be lubricated this way.
ianat182
