VicS
Now when i start it the oil light and buzzer are on and when i loosen the filter it will go off, if i tighten the filter while the engine is running it will run all day. When she is shut down and left for a while (overnight) then restarted the oil light and buzzer come on again!!!!
It sounds as though your oil pump is losing its prime. Slackening the filter allows the air an quick easy escape route. Once the pump is primed it runs OK.
More or less what Moonfire has already suggested
Just a theory, nothing else to suggest. Perhaps someone can come up with a better idea.
At least it seems that the electronic module in the panel is not the culprit. They are not cheap to replace when they fail!
