savageseadog
"Lot of armchair know it alls on here!"
The OP obviously is absolutely sure of that
It takes a lot of expertise in a cerebral field to afford such a fine fine vessel ?I have two armchairs on starboard. Direct to ignore. Do not pass go. Do not collect £200!
It’s a comfort to have your armchairs on starboard. You can relax, knowing that you are the ‘stand on’ seat. Everyone must give way to you.I have two armchairs on starboard. Direct to ignore. Do not pass go. Do not collect £200!
Aha. Exposed! The forum colregs armchair expertIt’s a comfort to have your armchairs on starboard. You can relax, knowing that you are the ‘stand on’ seat. Everyone must give way to you.
Forum armchair colregs expert surely.Aha. Exposed! The forum colregs armchair expert
Nope. If he was on a starboard tack, his armchair would tip him out and he'd land up on the port side.It’s a comfort to have your armchairs on starboard. You can relax, knowing that you are the ‘stand on’ seat. Everyone must give way to you.
Nothing worse than an involuntary armchair tack.Nope. If he was on a starboard tack, his armchair would tip him out and he'd land up on the port side.
So your starboard armchairs should be to port? This is getting confusing.Surely armchairs should Beto leeward?
Didn't Gypsy Moth IV have an armchair at the nav desk?I myself have rounded Cape Horn twice on my Parker (Knoll) 31. The second time really became a horrific experience when the recline mechanism failed
Surely William Pitt the Younger!?"Never believe everything you read on the internet"-
Winston Churchill
On the contrary. The beds up forward are probably no use for sea going kipping as one would fall out of them under way. Or in the minimum allow to roll about, as if in extra marital ( or non marital, depending on one's luck) activities.So your starboard armchairs should be to port? This is getting confusing.
Thank you kind sir. I think that is good advice. I know enough to know that I know nothing…..It takes a lot of expertise in a cerebral field to afford such a fine fine vessel ?
QED
Imo your boat is so beautiful that- this wood butcher- suggests you hire in in order to fix your locker teak top in the other thread and go with their hands on, day in, day out teak laying experience.
I thought it was interesting that the OP has probably had fewer posts than anyone commenting on the post.Just be aware there are some very dubious commentators on these forums from people who wouldn’t know a boat from a bathtub!The more complex the question the more doubtful the responses. So any advice suggestions etc double check. Sorry it sounds obvious but when you’re enthusiastic and want a response sometimes you want to hear what you want to hear!Having said that there are also a myriad of obviously knowledgeable members!
Yes, a very odd post from the OP - who seems to have been on the forum for 8 years but relatively few posts.I thought it was interesting that the OP has probably had fewer posts than anyone commenting on the post.
but the other 56% are accurate and meaningfulJust don't trust any of the forum statistics----74% of them are made up.
Dead right there!Cant fault your logic but of course you must also be wrong therefore I must be right???If the OPs view is that the forum posters are untrustworthy, then he himself must be untrustworthy, so his own post cannot be relied on. Logical, innit ?
