VictorII
During the weekend we had to motor about 9 hours a day and I noticed that a. the speed was lower than usual for the revs and b. I had to add transmission oil after every day.
Also, there was an audible vibration coming from the prop shaft under power which wasn't present before.
So I have these questions:
1. Can it be just a prop problem? Something around it or possibly electrolysis from some source (the boat has been in the water since August). In which case I will have to lift out.
2. Does anyone know which transmission it likely is? It's a Moody 36 of 1979 build. The previous owner told me to use SAE 20 oil but I read in the manual that transmission oil typa A is required for Hurth and Borg Warner. I looked the transmission over but didn't see a brand name. Does anyone know where to find it?
3. Finally, Can the vibration and loss of oil be related? (I would think they are) Any ideas on which's the cause and what the effect?
If it could be the transmission (a leak?) is there a manual available? What do I look out for for determining the problem?
Paul Victor
Paul Victor
