IanR
Having taken some advice I have removed my mainfurler from my in mast system, the worm gear runs on two bearing races which (forgive my terminology) consist of loose ball bearings running inside a large aluminium casting retained by a disc which has a concave inner to allow the bearings to roll around. In effect the balls are loosely retained and pretty stiff and high friction- were until I opened up the casing!!
Now the balls are loose (!!) and before I put them back I was considering these 15 yr old Stainless 5mm balls and I was wondering if I should replace them with nylon as they are not thrust bearings and have no real lubrication and would also be inert when in proximity to aluminium. Or whether I should consider putting in some proper bearing races in which case the aluminium will require turning to fit. But the races could be proper sealed bearings.
What would your thoughts be and if I should replace the bearings, with what type and from where...
oh and a final plea, If I was a fully experienced loose bearing loader what technique would I employ to temporarily hold them in place I have considered candle wax, butter,thick grease??
thanks "the apprentice bearing fitter" /forums/images/graemlins/blush.gif
