Jcorstorphine
I am looking to fit a Zinc anode to my 40 year old GRP motor sailer as I noticed a bit of corrosion on my stainless steel rudder when boat was lifted out for the winter. I have no idea why this has suddenly started and it may be an inherent flaw in the plate. The boat has been in a Marina on the Clyde for last 7 years but before that was on Loch Lomond for unknown period. My pontoon in the Marina is some distance from the larger motor yachts so I do not think it is a locality problem to third party stray currents.
The full inventory of metallic items immersed is as follows.
Stainless steel rudder (Spec not known 40 years old)
Bronze propeller (unknown SH off Moody fitted 4 years ago)
Bronze shaft (Stuart)
Bronze engine seacock (Stuart)
Bronze stern tube (Stuart)
DZR Toilet Seacocks.
A4 stainless steel bilge keel bolts (flanged GRP bilge keels)
At the moment there is no bonding whatsoever, the engine is indirectly cooled, the drive to the prop shaft is via a "Carden Shaft" with two Hardy Spicer couplings so there will be some electrical continuity between the engine and the prop shaft.
I am proposing to fit a sandwich anode to either side of the Rudder but am not at all sure if I should bond the rudder stock to the engine and seacocks.
Can anyone advise, thanks.
