shan
Are there any particular issues or problems one needs to look out for?
Engine bay access and check if the hull has a balsa wood core.
Neither of those relate to a specific boat - it will be the same for all Prestige 36s.
You also don't say where the core shouldn't be - nothing wrong with coring on deck and superstructures.
Would be nice is pascoe updated his stuff once in a while - most of his 'findings' relate to early/mid 90s boats. Things have moved on.
The Prestige will almost certainly be cored on the deck and superstructure - though it might be foam.
Engine access terrible both on the KAD and D4 version.
Impossible to change anode on D4 port engine intercooler due to rear bulkhead, fuel pre filters sited in a stupid place whereby you could not safely change a filter at sea.
Over the years I've changed and repaired many gearboxes HS63 due to the filters and oil not being changed as again access not goodeadung to gearbox rebuilds.
Leaking exhaust elbows trashing the EDC wiring , early stern glands leak, seacocks and skin fittings sub standard quality, leaking hot water tank, corroding exhaust hull fittings.
Something to go at there.
That's the P36 off the list, so
If you were to have a (max) 40ft fly-bridge, what would it be and why? (Sorry to de-rail, but may help OP if he's starting his search again)
That's no reason not to buy one, ive many clients over the years that have them and are very happy with what they have got , both the 32 and 36 are good value for money boats , I'm just giving you the heads up on my daily job as to what you may come across.
P36 not off the list yet mainly because what I really want is out of the price range!
