RichardS
N/A
Ca anyone remember the question?
The question is "Was the line set by the sun" and the answer was given in post #5.
Richard
The choice was between Greenwich and Paris.
The conclusion was that while sailors were happy with having 'GMT' I don't think that there were many who were looking forward to having to live with 'PMT' all their life...![]()
Just did a forum search and apparently not.![]()
But in this case time is derived from longitude. In the sense that you have local time everywhere (noon when the sun is overhead,
What I was fishing for was - Once it had been decided that a global meridian was needed, was it plonked down in Greenwich at a declared longitude of zero at the sun's highest altitude and then clocks set to 1200? Or was it the other way round?
Thereafter LHA would give angular distance from this meridian.
Wouldn't it have been plonked down in Greenwich at a declared longitude of zero and it then declared that when the sun was at its zenith on that meridian it was noon GMT?
So time was set to the line?
GHA and all that.
That's what I was looking for confirmation of.
I hope you now have itThat's what I was looking for confirmation of.
What other rational alternative is there? The time sets itself (solar noon). Surely the only variable is the reference position?
All the primary meridian is a reference point. A bit like "Aries".But with reference to what?
I assumed the reason I could not find a zero difference between noon and the GHA was because either the original fix was inaccurate (inevitable eventually) or the earth is still wobbling (it is).
The nearest I found this year was April 16 which showed a 3' angular difference.
Never seen this before. Not sure that I fully understand it. Can you please add the missing X axis and explain its use/interpretation in relation to the Equation of Time? (and possibly to the latitude of the observer).
This is the analemma, it shows the difference in position of the Sun from the mean on a given day and time. The x-axis is deviation of the apparent longitude, equivalent to deviation of apparent time.
The standard graph for equation of time has the x-value of this plotted (on the y-axis) against time of year. This makes sense because latitude of the Sun is not relevant to time (longitude) calculations.
If you look at the Wikipedia article for equation of time you will see a graph of deviation between sundial time and mean solar time:What is the purpose of these two graphs? For what are they used?
