davidmh
I hve recently found out that all the Lofrans winch now have an anti-seize grease smeared on the stainess screws to prevent them seizing, This is good news if it is correct. The grease thay use is System 251 Antigrippante Al Rame by Arexons. Ant of the forum have good Italian? It comes up o google and there is a spec sheet. Does it sound like something that would prevent the seizing of the bolts?
The Royal unit is very simple and although it is slow and manual itb is ideal for some people and half the price of the simplest electric unit when you consider the wiring needed. What I like about the Royal is that you hand just lift the chain out of the gypsy and haul it in by hand with the chain going down the hawse pipe and then when it gets tough you just just drop the chain back into the gypsy.
Any of the chemists on the forum, I would value your view on the System 251 grease.
David MH
David MH
