Locking wing-nuts?
  • Thread starter Thread starter Ric
  • Start date Start date
Ric
8 Dec 2003
Do wingnuts exist with inbuilt nylon lock? I have a reel for the kedge line and need a simple system to vary the unreeling friction. At the moment the spindle is controlled with a 10mm locking nut, which works great, but I have to use a spanner every time I want to adjust it.
Why not use a 'slit locking nut' - sorry cant remember the name for them but you could weld a 'wing' to it without destroying the locking facility as they are all metal.
AERONUT or BINX are some. possibly CLEVELOK ?
I reckon any form of 'brake' for an unreeeling anchor warp is going to need to be a lot bigger in area than the inner thread of a nyloc nut. The energy involved in stopping or slowing reel and warp (say15kg) will melt the frictionising surface fast.
A big knurled knut on a 12mm thread, with a couple of large washers of dissimilar materials (say steel and bronze) might be the answer.
Come to think of it, we have them on the electric fence reels on the farm. :)
http://www.electricfence-online.co....ctric-fencing-wire-tape-rope-reels/reels.html
How's about?-Put a wing nut with the biggest 'ears' you can fit on first(after a couple of large washers).Slide on a Spring washer.Then put on a Nyloc nut.Adjust the wing nut until you get about the right friction,use the nyloc nut to hold in place.The spring washer allows you to 'fine tune' the friction.
Just a thought.
Cheers
The problem is that a nyloc and a wing-nut are designed for diametrically opposed purposes. A wing-nut is intended to be quickly and easily adjusted by hand, whilst a nyloc is intended for a once only use and to stay put. The nylon wears out fairly quickly if you re-use the nut. As already said, you really need to increase the surface area so that a lower pressure gives the same overall friction.
Rob.
Yes.
