MikeBz
Thanks, I wasn’t aware of that (have now looked it up and seen the graphs). Maybe this is less of a problem in vehicles (and static power stations), I guess because they have a huge number of cells and use an inverter so the total “source” DC voltage isn’t critical?Not great for retrofit to anything 12 or 24v. The voltage range is 15v to 8v to use the 100% capacity. How would you boat handle those voltages. If you narrow your operating voltages to replicate lead voltages, you lose capacity so need more batteries.
I am yet to be convinced they will replace lithium
CATL will start production of an NA battery this year with an energy density of 175Wh/kg, cost of $19/kWh, 5 x life of Lithium (not sure which one) and 90% capacity at -40C. The lower end of the EV market will start to use NA in some volume IMO.
I think that right now battery technology is about where combustion engines were in the 1920s or 30s - it’s got a long way to go but it’s moving fast. That’s why I’d be reluctant to buy an EV now even if I could afford it, unless I was wealthy enough to be able to blow thousands of pounds a year on vehicle depreciation (which I probably could, but still wouldn’t, if I didn’t own a boat).
Anyway I’m really drifting off topic here so I’ll shut up.
