JT14
New Member
I'm installing a single Renogy 300ah Lithium battery (with internal BMS) as the house bank on our Rival 32. Starter battery will remain as the 100ah lead-acid, with a Renogy 40A DC-DC charger between the starter and house bank. Engine alternator puts out 40A, with output regulated to 20A on the DC-DC so as not to burn the alternator out when engine is running.
We are a long-distance cruising boat, and rely on our solar panels for regeneration, therefore the low output from alternator is not too much of a concern as we spend most of our time sailing. Potentially in the future we will upgrade to a Balmar system, when the wallet allows.
Solar: We have 3 x 100W panels. Each panel has an individual MPPT, two of which are Victron (and programmable to Lithium) and one is a cheaper unit that cannot be programmed.
I'd like the starter battery to be trickle fed so when we turn the key we have a full suite of cranking amps. This lead to our thinking about MPPT placement in this setup, to gain the best regeneration potential for both banks.
Option 1: We could put all the solar MPPT's on to a common bus which feeds the starter battery, with the DC-DC charger on the same bus. The thinking here is that once the starter battery reaches 13.2V, the DC-DC will kick in and start feeding the lithium house bank. This seems simple enough, but will the internal resistance of the lead acid reduce efficiency to the lithium?
Option 2: Two 100W panels are wired to the lithium house bank, with the other 100W feeding the starter battery. This is the simplest solution I think, but we do stand to lose the extra charging capacity from the 100W panel that is reserved just for the starter battery. 3 panels take up a lot of space on our small boat and to not gain their maximum output into the lithium bank would be frustrating.
Option 3: One Victron MPPT to lithium, with two 100W wired in parallel. The other Victron MPPT with a single 100W wired to lithium. Buy a new, small panel of 20W ish, to trickle charge the starter battery with the last MPPT.
Space is a at a premium right now, and adding another panel somewhere would be tricky - but that's the only downside of Option 3.
Finally, for option 2 & 3 - when the starter reaches 13.2V, and DC-DC starts feeding the lithium bank - will this trigger the lithium MPPT's to stop charging, or can the lithium accept multiple charging sources in these cases?
Thanks in advance for your input and experience!
