Lithium batteries
There is no such thing as drop in replacement. You can't simply take out lead and drop in lithium without considering your system as a whole
As I thought, mine is a ‘drop in’ if I do not connect the engine. I have wondered if simply connecting the alternator to a charge controller would do it, but of course all the connectoins for starting and charging are inside the engine hood. I have just 2 x 6mm2 cables. Things are rarely as simple as you think.
You still need a class T fuse. Selection of a battery with adequate BMS rating for your load. If you are charging with solar then a smart shunt makes sense to accurately control the solar charge and give a true reading of SOC.
That's all easy compared to dealing with the alternator. And if I am running the fridge, the nav lights, plotter and heating, my load would not exceed 25A, even with both fridge and heater in start up.
I currently(groan) have 180w of solar, and 148w of alternator, we use the engine very little. I could easily add another 200w of solar on the outrigger floats if I needed to. Nav lights, cabin lights, instuments, fridge, diesel heater on the load side.
Just regarding solar panels. it seems to me that modern domestic solar panels are a lot more efficient than they were 10 years ago. This guy Buying Solar? Don't Pay 'BMW' Prices For A 'Kia'! seems to expect a single solar panel to give 400watts. Now I assume a physical size somewhat similar to old panels because that is about all a single man can handle.
I have some I think similar physical sized panels at 150w and others more modern at 180w but still 10 yo. My point is that you may find it worthwhile to replace existing panels with their mounts than add more. Note here I am talking domestic PV panels not so common in UK but every where here in oz. High voltage like 40+ volts so must have a capable MPPT. Worth research I think. ol'will
The UK market has a good selection of 300 - 400w and larger glass panels. However, he sails a light weight trimaran, so an arch and a couple of glass panels isn't going to be fitted.
True. What I do have is lots of deck space that is mostly not walked on routinely. And certainly never covered when sailing, I could get more than I previously said if needed, but our needs are quite modest. When folded on our mooring, the floats are partially shaded, so only the foredeck will get the sun then. Making the most of it is going to require some thinking.
You might consider a battery switch to completely isolate the LFP from the domestics. Then an emergency switch from a small but good quality engine start lead acid to feed the domestics in an emergency. For example the BMS has a hissy fit and shuts down just as your coming in through the Needles at night with no lights. Turn two switches and you are back in action for some hours on the engine battery.
Mine are wired like this. Not because of LFP, but I had a fright two years ago when I could not isolate a battery easily so all my batteries are now on individual T-class fuses and isolators. Including the engine FLA.
My boat was built with class T equivalent fuses on windlass, engine and domestic banks. That was 43 years ago. The Lithium now joins the club
