ashtead
Has anyone recent experience of fitting as house batteries and what sort of price /issues if replacing AGM batteries and benefits for a given size?
Yes but lithium ion used in cars and lithium iron phosphate used in boats are completely different batteries so your point is moot since the LiFePo4 are quite safe.If a car's lithium batteries catches fire you can quickly stop and get out. Not so easy on a boat .... Apart from the cost that would be my major concern.
Tesla have used lifePO4 in their entry level cars where range is not such a factor because it is inherently safer that some of the lithium technologies offering higher energy density but the added risk of fire. The risks of LifePO4 are pretty low. It seems to me that the risks on a boat come from poor installation not the batteries themselves. The biggest single risk seems to be BMS failure that allows serious over charging but even then they don't seem to burst into flames but they get exstremly hot and smoulderYes but lithium ion used in cars and lithium iron phosphate used in boats are completely different batteries so your point is moot since the LiFePo4 are quite safe.
The pros sound great, what of the cons ?!!
It sounds like for you and your boat it was a great choice. For us the benefits are marginal and for weekend sailors the cost of doing it properly would not be worth it.LiFePO4 do not catch fire.
EWe converted our boat a year ago and it is one oif the best things we have done. But we have done it properly, we have replaced our alternator to a Balmar lithium compatible unit and we have fitted separate BMS units.
The thing about Lithium batteries is not so much that capacity increases which it does, it is the speed and ease of charging. So as soon as you start your engine, we are putting in 90A at 24v that's about 180A at 12V. Our solar puts every bit of energy into the batteries no matter the state of charge and if we do plug in our start the generator we charge at up to 220A at 24V.
The result is that we can go from 50% to float in 90 minutes with our genny in the past it would take 14 hours to get from 60% to float with lead acit batteries. The energy, noise and fuel saved is amazing.
To do it properly requires a lot of upgrades as your existing cables will not be man enough to carry the charging current. If you are in the Hamble I would contact Paul Knight of Knight Marine. The work he did on my boat is fantastic.
Your opening gambit is false so I won’t bother reading the rest.LiFePO4 do not catch fire.
Thermal runaway isn't the same as a blazing fire. I cannot find a single confirmed image of a LifePO4 battery with flames billowing out. They seem to smoulder and smoke but no flamesYour opening gambit is false so I won’t bother reading the rest.
For everyone else , they can and do suffer thermal runaway if mismanaged.
The lithium-ion used in car batteries is not the same as the lithium-iron-phosphate used in marine lithium batteries. It's like saying: "I wouldn't eat sodium chloride because sodium burns on contact with water!"If a car's lithium batteries catches fire you can quickly stop and get out. Not so easy on a boat .... Apart from the cost that would be my major concern.
Lead acid toothey can and do suffer thermal runaway if mismanaged.
I never suggested otherwise
