srm
I rarely have the problem of crowded anchorages but would often leave without messing around with the engine so some of the following may help.
Control the tiller - a simple line and clamp, or trad boat type beam drilled for pegs will help (or tiller pilot but prefered a fixed clamp). Set tiller (or wheel) so that stern will swing when boat drifts astern and point the bows the way you want to go (about 95% reliable provided riding head to wind)
Haul in and stow chain until anchor chain is up and down.
When ready and bow is swinging the way you want break anchor out and bring it to stem head as quickly as possible (or in water clear of bow as previously suggested) This way you only have chain equal to depth of water cluttering the deck or a short length to quickly wind up on the windlass.
Return to cockpit and unroll (or hoist) jib and sail slowly into clear water while stowing anchor etc.
Round up and set main if required.
No cameras, remote controls or other things to go wrong. Worked well with 42 ft sloop and 30 kg anchor as well as on 31 ft catamaran and 15 kg anchor.
You will have to plan ahead and possibly change some of the things on your foredeck. Possibly a hatch to the chain locker so you can dump chain straight in would help.
