If you google fast worker for sale , there is one in holyhead with a winch and spencer and carter power pack but it does not say what it can lift , good luck.I have a Fastworker 19 workboat and have access to a contract to drop and recover moorings with weights up to 350kilos. Need a way of getting them on and off boat safely.
These are my 2 options at the moment
2000LB Swivel Truck Crane (900kg)
This will do up to 900kilos but am worried about lifting from alongside boat as is more unstable
https://img.nauticexpo.com/images_ne/photo-m2/63904-11356801.jpg
Other option is an A frame style like this but probably without hydrolics
Any more options let me know
Both will need some changing and engineering which I’m willing to do
@Rberrow1 you are doing the same as what so many others on here have done before you, where you ask for help and / or advice.
In response, opinions are freely given telling you that it is a crazy idea, yet you are already in denial, and trying to justify your proposal as being workable.
Please - listen to and take heed of the sound advice given above - you do not want to be working anywhere near the margins of stability or safety on a job like this.
What you need to understand that every piece of lifting equipment , that has been designed and buit , has to have been certified by someone who can issue a loller certificate , with a safe working load proven , then has to be tested every 6 months . if iam correct.
Is the OP still with us? ?How did it go?
The OP has only ever posted on this thread, and hasn't looked in again since a couple of days later (18th Nov).
Nice potato cam, almost like an impressionist painting.
