Refueler
I posted this many moons ago - but its got lost in the mists of time .....
I really do not like the thigh straps that are provided by manufacturers .... they work - after a fashion - but are awkward when you move around ... if you sit down - the loop tends to drop down the leg and then when you stand up - it tightens ...
So I did a bit of thinking and decided to modify from around the thigh - to actually a crotch strap .... so you can move around easily and no interference.
Good grade webbing ..... strong seamans waxed thread ... palm and needle.
It is far easier to put on ... basically put on the jacket ... reach under your ar** for the strap and the clip at front ... pull tight if needed ...
