sailingrbg
Can anyone advise on the following, I currently have a valise Life raft but due to the fact that I keep it down below on a 27' yacht it does take up a bit of space, to this end I am considering going for a canister type and to mount this on the transom stainless steel rail, my questions are as follows
1. While the transom rail looks quite substantial how do I know if it would take the weight of a canister life raft @ about 30Kg
2. With the outboard engine 13.5kg and the life raft @ 30Kg on the other side over the rear stern does this mean that I will have to compensate for additional weight in the bow in the from of added chain
3. I notice that sometimes when motor / sailing that the exhaust outlet is sometimes beneath the water my main concern is that placing this additional weight right at the rear may mean the exhaust outlet could be much nearer waterline or partially submerged, would this constitute any problems?
Any thought or suggestions gratefully received
