symondo
Ive been trying to be less on the internet and more 'doing' the jobs im supposed to be doing recently
Ive managed to install solenoids for the drive lift on my bayliner.
However...
Down appears to click - not activate the pump (old solenoid)
Up doesnt do anything - leg is up so i guess it could be the limit switch (new Solenoid)
now - ive taken the wires off each solenoid - the motor runs up and down - with fluid being pumped at the leg in both directions when hooked up direct to a battery.
Ive had a meter on each cable
'Down' appeared to show 9.8v which is pretty poor
'up' showed 11.9v upon pressing the switch in both directions.
Im aware both voltages arent hitting 12 so a battery charge is probly required (thats another story)
what im more puzzled by is the really low voltage on the down switch wire. would it be down to corroded old cable?
Also i think i will have to have both solenoids out and on a bench test as im not fully convinced they are functioning properly either. If i short a 12v wire onto the switch terminal - it still clicks with no active output.
the earths and circuits all appear to be full with a continuity test - could it be a dodgy cable - low voltage or a duff solenoid - or all 3?
However...
