Thepipdoc
I'm considering buying LED's for under shelves, ledges, seating etc.
They are supplied with a 240v to 12 volt dc transformer - see spec below.
The question I have is, can I wire these LED's to run directly from the boats battery source? ( this might seem like a daft question but I'm really not sure!)
* Self adhesive, ultra high output LED strip lighting
* Ideal for many applications including display, decorative, sign, under-shelf, and emergency lighting
* Flexible strips can be applied to curved edges such as pillars and tubes
* Allows for frequent cut points anywhere along the length of the strip, power is then provided at the adjacent connection point
* Different colours can be combined, with solder points every 50mm
* 60 LEDs per 1m length with 15mm separation between each LED
* IP54 rated
* LED Strip Kits comprise of 2m length of LED Strip lighting and a 10W 12V LED driver
* Addtional lengths of LED strip are available in 1m lengths
* Additional LED drivers will be required if exceeding 4m length of LED strip or if exceeding the power supplied by the original driver
Technical Data
Voltage 12V DC
LED Power (Single) 0.035W (R/Y), 0.08W (B/G/W)
Operating Temperature -40°C to +85°C
LED Strip Dimensions (WxD) 10 x 2.5mm
* IP54 rated
Technical Data
Voltage 12V DC
