Angele
I think I know the answer to this, but just checking.
I want to replace the conventional bulb in my anchor light (which, incidentally, has just blown) with an LED replacement bulb - keep the fitting, just replace the bulb. I'll get it from Boatlamps as they seem to know what they are doing.
There is a warning on their website as follows:
Now, my AIS uses the same antenna as the VHF (thanks to a splitter) which is, not surprisingly, located next to the anchor light and I'm not about to move it. But, since this is only the anchor light I am talking about and I have no need of either the VHF or AIS when I'm at anchor, I'm assuming this is not a problem. I take it there is no way an LED bulb can interfere with AIS or VHF if there is no power going to it.
I don't have a tricolour, so there is no other light at the top of the mast that could interfere with AIS/VHF. For those who do, has anyone noticed any reduced AIS effectiveness as a result of the interference from an LED bulb?
Try to mount AIS and other sensitive antenna remote from all LED lamps, as far is practicable. Some sensitive receivers can be affected by the low level of EMI emitted from LED lamps.
