Flica
Jaguar 21, 6hp Tohatsu 4 stroke
I've recently taken on this boat so a few elements need pondering:
I have a baffle for when the outboard is removed but have heard talk of baffles that go round the outboard leg. They sound a bit fiddly to me.
The Tohatsu won't fit in a cockpit locker the right way up. Well maybe it does but I haven't worked out the spatial puzzle. It is quite a tight fit in its well.
The Tohatsu has the ability to charge the battery. This is a plus.
The Tohatsu does not have an effective steering lock. This is a minus.
Time will tell if I need 6hp. At the moment I certainly don't use it at full throttle and it seems to push us along nicely against wind and tide. Might try with 4hp which would be lighter, smaller and fit in said locker.
I completely agree with Seajet regarding 2 strokes. Would be good to do a weight comparison (Tohatsu quoted at 25kg for 'lightest version'). I've always had two strokes in the past and am used to their foibles.
As to corrosion, chips in the paint and bare alloy need covering. On reflection I probably don't need to antifoul (well not for the winter) after all I can always pull it up and give it a scrub.
As you may judge my thoughts are veering from whether I should leave it in the water to whether I have got the right engine...
Michael
The Tohasu 6 hp (basically the same motor as the 4 and 5hp) weighs 25kg.
Surely no excessive weight to lift and probably there appear to be no 4-stroke engines of a similar output at that low weight available on the market.
Possibly you can attempt to find a 2-stroke of similar output, which will be considerably lighter, but would, of necessity be second-hand, unless you can get to Maynbrayce in Alderney or to Malta where "grey" imports are available.
As Sea-jet has already pointed out, leaving the outboard in the well under sail, cripples performance, and leaving it down, moored, will result in accelerated deterioration.
On the whole I'd try to dissuade anyone from considering your proposed actions.
Why not mount a pad on the pushpit and mount it there?
