Obi
I have a Perkins engine with a primary filter. After picking up some slush from the bottom of the tank, I overhauled the fuel filtering system, including new primary filter and o ring seals. The part I got was from partco, a unipart, but looks the same.
After fitting, priming etc, I found that the seals were leaking. I tried the old seals, which I had previously removed, with the new filter, it still seeped out of the large rings, so I replaced the old filter and old sealing rings to see if this improved matters. It was then worse.
I dont want to over tighten. Can anyone suggest anything? It really looks like all the seals and filters are lining up and fitting into thier appropiate reccesses.
The one o ring I didnt change is the one in the filter housing - Ill try and explain: I removed the filter element, there are 2 large seals which sit top and bottom of the filter element, there is a third small one which fits around the retaining bolt and inserts in the top of the housing, there is a fourth which bits around the guide the filter element fits over, this is the one i didnt change, and I dont think it can be responsible for fuel seeping from the top or bottom of where the housing and element meet.
I have read on this forum about using fibre seals to solve seeping filters. Is this really a silver bullet/magic bean for this problem? If so, where can I get them?
Any advice please?
Obi
Any advice please?
Obi
