rays
Spotted some corrosion on aft end of engine but couldn't spot the leak. Thought that it was from the water pump which had previously been repaired. After sitting behind engine for 10 minutes and watching the pump have now seen drip from back of water pump. The shaft seal (?) is leaking. Engine is 10 years old but only done 300 hours. We are heading off to Holland in two weeks so need to fix the problem. Is it worth getting the pump stipped down and the seals/shaft replaced, re-fitted and tested or would it be better (if a bit more expensive) to get a new pump and (when time permits) service the old one and keep it for a spare? One thing is certain, I don't want gto set off across the North sea with a problem pump!
What would you do?
What would you do?
