biscuit
Yet another season starts with leaking cable glands. My deck stepped mast has to be refitted every year, this time after missing a season due to lockdown. I have tried different cable glands, and settled for Index Marine seals.
There are several issues:
1. All connections have to be removed from the cables before threading through the holes in the rubber blocks, at the start and end of each season. The ridiculously fine electronic wires from my Garmin masthead wind (linked to depth) need retinning and careful protection from the elements as the mast is outside all winter. They sometimes need re- doing, so the cable is getting steadily shorter! The thicker 12v lighting wires and vhf wires are less of a problem.
2. How do you bore a neat hole through the rubber blocks? OK, an electric drill, but its very hard to get the right size hole. Putting the block in a vice to drill simply distorts the rubber. Any advice welcomed. Putting a slit in the block may be ok in theory, but always seems to leak in extremis, and sealant is of only temporary value.
Not rocket science, but an annual annoyance.
Any ideas most welcome.
