Adrianwool
Any ideas?
I have a freshwater leak which puts a gallon or so of water into my forward bilge after a heavy fall of rain. Things tried so far
Anchor locker covered to prevent any water draining through any defect, anchor locker inspected dry!, hose from locker dry!. water still turning up in bilge.
Diesel fillers & pumpout covered - water still in bilge.
Engine air intakes covered - water still in bilge
Engine box perfectly dry it has two sealing bulkheads and is consequently self contained from the rest of the boat.
Cleats examined minutely, no signs of damage looseness or cracks
Window and windscreen seals intact and dry.
Inspection with a lamp shows no dampness in all areas (including those where you need to be a double jointed monkey!.
The rubber strake between the hull and topdeck and hull is intact and undamaged
AAGH inspiration PLEASE
