pvb
The other thing to be concerned about is a short circuit fire. Can you get to the disconnect switch in time?
A simple fuse fixes that risk.
OK for domestic batteries where total load may be only 20-30 amps max. But what rating fuse do you put in the starter battery circuit ?A simple fuse fixes that risk.
200 amp? = potentially 2.4 Kw of localised heat in a short-circuit before the fuse reaches it's rating.
500 amp? = 6 Kw
Well, yes and no....OK for domestic batteries where total load may be only 20-30 amps max. But what rating fuse do you put in the starter battery circuit ?
500 amp? = 6 Kw
I also wondered about the --series-- commentHydrogen will set off the gas alarm at very low levels.
Put a small vent in the storage area and the Hydrogen will quickly escape.
I presume you mean put the new batteries in parallel, rather than converting to a 24V system.
If you have a complete short then the load (and heat) is spread all along the cable, which provided it is properly rated can carry at least the expected load current and therefore the fuse rupture current.
If you have a partial short, then yes virtually all the heat is in one spot which is most likely to become either open circuit or total short at such power.
In the unfortuneate circmstance where there is a fault that is a partial short that remains so, then yes you have a fire, but no simple protection device can help in that situation. So fuses do work, fuses do protect cable, equipment and batteries, not in all cases, but certainly in some.
I agree with this. I still do not like the idea of a fuse in the starter circuit: on a really cold day I'd rather the starter cranked rather than a fuse blew, and if you fuse at a rating above the absolute worst-case amperage for the starter motor it's not really going to give much protection if there is a localised "hotspot" in the circuit.
Are there any preferred brands I have to look out for... I see Amazon offers fairly priced numax 110ah...
Thanks...
Yes, but something connected to the cable, or perhaps a damaged/weakened section of the cable itself could have a slightly higher resistance than a dead short but still pull though enough current to generate 150x12 =1.8 Kw of heat which is quite enough to cause a fire if next to something flammable.The fuse is to protect the cable, which can handle far greater current than the starter motor will ever demand.
I knew I had a diagram somewhere ... found it
Actually a good idea to connect the positive lead to one of the pair and the negative lead to the other
But you don't need to increase the capacity of the starter battery do you? Would you not do better putting all the extra capacity in the domestic bank?
.........tens of thousands of production boats are sailing around with no battery-line fuses, only individual circuit fuses or circuit-breakers.........
Good evening,
I probably have what many would consider a newbie question, but I could not find any clear answers in the other posts on the YBW forum site.
We currently have 2 lead-acid batteries installed under our main lounge seating, 1 for the engine and 1 for leisure. I am looking at adding a couple more batteries in series. So far, the existing ones are working like a charm, but the question remains, are they safe? Do lead-acid batteries not emit fumes or do they pose a potential health hazard, especially for the ones nearest to the batteries at night? Would it therefore be better to have AGM or gel batteries or is simply an urban myth? Are they to be put in a separate box or should I put them in the area in the cockpit area under my outside seat area?
Any advice would be much appreciated.
Thank you in advance.
