lumphammer
We have a Lavac toilet with an electric pump. When I put the smallest bleed valve Lavac do into the inlet pipe I don't get enough suction to flush the toilet, but when I block off the bleed valve, although I now get a decent flush I am also getting siphoning that gradually fills up the bowl till the water reaches the sea level outside, fortunately that is just below the toilet rim!!!
I am at a loss to know what to do. I'm assuming that if I had a manual pump I would be pumping faster than the electric one and thus providing enough suction to overcome the bleed valve. Is the position of the bleed valve important? I have just inserted it at the highest point in the inlet pipework.
Any other suggestions gratefully received.
